Hi I'm new to the forum, I have a Satoh buck that I am trying to get running for a friend. It has been sitting for awhile and the alternator and regulator was bad. I did a search here and found a few guys asking questions about going to an internally regulated alternator but no real good answers.
Heres what I did, it turned out to be pretty easy. I bought a GM style Mini alternator from DB electrical. It's a one wire hook up and the modification to install is minimal. All I had to do was drill out the mounting ear on th block to 3/8 and flatten out the tension arm. The biggest problem was removing the radiator to drill out the mounting ear.
I could use advise on what to do with the fuel system to clean it out, it was stored with fuel in it and the fuel bowl was pretty gross when I opened it up so I'm pretty sure the tank is nasty as well. I was hoping that there is an adative I could use to clean it up.
