Satoh Bison S 650 G
   / Satoh Bison S 650 G #1
Anonymous Poster
Epic Contributor
We just purchased a S650G and need to know where to check the fluids and what kind of oil to use.thanks in advance
   / Satoh Bison S 650 G #2
I don't know if this will be much help, but my copy of the service manual for my old Satoh 650G indicates <font color="red">Turbine oil No 120(Capacity 0.92 gal - 3.5 lit </font> <font color="black"> this is for the hydraulic system.
For the engine I use the same oil as my autos. </font>
   / Satoh Bison S 650 G #4
If I am not mistaken his tractor is a 4 cylinder gas burner. 650 G and the G is for Gasoline.
   / Satoh Bison S 650 G #5
Thank you for the correction, I didn't realize that satoh had a gas machine. I remember the beaver, bull and bison, just assumed that they were diesel.
   / Satoh Bison S 650 G #6
Yes this is a gas tractor so use a good 10w30, 10w40 engine oil, whatever brand you prefer. Your transmission and hydraulics are separate so use any one of these - JD type 303, Universal tractor fluid, Aw46 tractor hydraulic oil or the equivalent in your hydraulic reservoir under the seat. Check the level on the left side thru the sight guage on the older models or the level plug on the later models. Your transmission uses 80w90 gear oil and the level plug is on left side by your foot when it iis not on the clutch. I sell parts and manuals for your tractor that will help you with all of this. The illustrations are very clear and the quality is excellent. Call 800-609-5110 Bill Rodgers
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
(2) 300 GALLON POLY TOTES (A51248)
(2) 300 GALLON...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2019 FREIGHTLINER...
40' CONTAINER (A51248)
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
