Satoh Bison Muffler
   / Satoh Bison Muffler #1
phmezz
I need to replace the exhaust on my Bison 650G. I'm replacing everything all the way to the manifold. I talked to a muffler shop who can make the pipe for me but they say they don't have a muffler the size I need.
Can anyone recommend where I can get a muffler.
Also, they need to re-use the old flange. Any ideas on where I can get a flange just in case I run into a problem.
Thanks for any replies.
   / Satoh Bison Muffler #2
I have a S670D Bison, and replaced the muffler last year. I used the stock heavy flange and had a local muffler shop use a glasspack with rounded ends and welded it to the flange piece on the bottom and for the top I had them put on a 90 degree piece with a sliced end skewed away about 45 degrees to the left away from the front. It works great and sounds good to, a little loud, but OK.
Thanks for the reply. I ended up buying an Allis Chalmers muffler at Tractor Supply (the cheapest one) and took it to a muffler shop. They cut the flange and ran new pipe the rest of the way. I clamped the pieces into place and all is good. It turned out to be much easier than I thought.
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A53472)
2019 New Holland...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
JOHN DEERE 17P LOT NUMBER 227 (A53084)
JOHN DEERE 17P LOT...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
2013 John Deere 824K (A53472)
2013 John Deere...
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
