Satoh Beaver Hyd help
   / Satoh Beaver Hyd help #1
dunerdr
Jinma 284
Hey all, my brother in law called me up last night stating that he was having problems with his 3pt staying up. The tractor is a satoh beaver that he has had for about 15 years and just recently started having the problem, i dont know much else about it. It lifts and lowers fine but to get it to stay up the lever must be held in the neutral setting. if you let go of the lever, it just falls into the lower setting and the hitch drops. It seemed to me that there was probably just a bad detent so we pulled the cover off and found that there are no detents or springs to keep the lever in the neutral position. it will stay up if the flow control valve under the seat is shut, the system pressure is at 1950, and the FEL works fine. because there are no detents im assuming that the spool valve for the hitch is bad? just trying to get another opinion before we order parts.
   / Satoh Beaver Hyd help #2
Could there be a friction disc that could be tightened?
there are no friction disc involved in the 3pt system. The actuation lever is connected to a shaft that runs the control valve. simple as that. what i dont get is that there are no detents, the spool valve isnt spring centered, nothing. so.... is the valve centered by hyd pressure? if so, the fact that it wont stay centered would indicate that the valve is bad? correct?
   / Satoh Beaver Hyd help #4
My 470 is like that but stays where you put it. Will try to look in my service and parts manuals for a clue.
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
More info coming soon! (A53421)
More info coming...
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
UNUSED RAYTREE RMBD72S - 72" HYD DRUM MULCHER (A54757)
UNUSED RAYTREE...
CAT 416B (A47477)
CAT 416B (A47477)
