Satoh 650g valve adjustment????
   / Satoh 650g valve adjustment???? #1
dandunkle
Tionesta Pa
Satoh S650G
I just bought a Satoh 650g and i was told it needed a head gasket. so i finally found the head gasket, installed it, adjusted the valves and put new plugs wire points condesnser etc. on..... Now that i got it back together when i try too start the engine it will backfire out the carb a little and run at a very low idle just puttin (barely runnin) for about 15 seconds and quit.... Im thinking maybe i adjusted my valves improperly or somehow i got it out of time????? can someone give me detailed instructions on how too adjust the valves? also the firing order and witch cylinder the plug wires go too from the distributor cap??? Im not really sure what too think, its got me baffled... any help or suggestions would be greatly appreciated! Thanks
Kubota BX2230D (A47384)
Kubota BX2230D...
7pc Mini Excavator Attachment Set (A51573)
7pc Mini Excavator...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
