Dec 1, 2005 / Satoh 650G steer box oil change #1 B Burnie46 New member Joined Nov 30, 2005 Messages 3 Location Northern Pa Tractor Satoh S650G If I take off the three bolt plate on the right side of the steering gear box, can I change the oil or will bearings fall out!
Dec 3, 2005 / Satoh 650G steer box oil change #2 L lens12 Veteran Member Joined Apr 7, 2000 Messages 2,113 Location Dixon, Il Tractor ford 9700, tw30, massey, jd2030 jd4010, yanmar F60d, ym330d, ym276d,ym226d,ym186d, ym2000, ym155 The bearings will not fall out if you loosen the plate.
