Satoh 650G PTO stopped
   / Satoh 650G PTO stopped #1
trac
Niagara County, N.Y.
Long 530, 2360, 360,2310, Ford 641, 8N, 2N
While mowing with the tractor in light grass, the pto stopped turning. Everything is engaged, and the transmission clutch works perfect. Any ideas on this problem? Thanks for the help. Trac
   / Satoh 650G PTO stopped #2
Some models have an independant pto that has 2 clutches. do you know which style you have?
Just an update. Removed the 3 pt. top cover. The problem was at the over running clutch. A hub washer had broken allowing the spring to sprial around the snap ring that holds the assembly together. Replaced the washer. Works great. Trac
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
2017 HINO 268 BOX TRUCK (A54607)
2017 HINO 268 BOX...
2015 Ford F750 Reel Loader Truck (A52377)
2015 Ford F750...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2018 FREIGHTLINER BOOM TRUCK (A51406)
2018 FREIGHTLINER...
2022 Allmond Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2022 Allmond Bros...
