Satoh 650 G Valve Cover Gasket
   / Satoh 650 G Valve Cover Gasket #1
jshanley
Montana
satoh 650G
I have a Satoh 650 G and I'm looking for a valve cover gasket. It currently has a molded gasket attached to the bottom of the valve cover and I have checked at all parts stores giving them the mazda 1200 model with no luck. Any suggestions would be greatly appreciated.
   / Satoh 650 G Valve Cover Gasket #2
I've used blue RTV in a pinch with good results. I put on a bead, tighten it finger tight and when the RTV sets up tighten it snug.
Thanks for the info... Got it covered...
   / Satoh 650 G Valve Cover Gasket #5
hi
I posted the wrong number for Small Import Tractor there number is 503-628-6319
   / Satoh 650 G Valve Cover Gasket #6
When using the Blue RTV, coat 1 surface with a THIN coat of oil and let the silicone "skin" before assembly. This will make a re-movable, re-usable gasket. It is pretty cool when you get it right.:thumbsup:
2011 Chevrolet Cruze Sedan (A50324)
2011 Chevrolet...
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
2015 Ford Fusion Sedan (A50324)
2015 Ford Fusion...
3 PT 10' V-Plow (A50120)
3 PT 10' V-Plow...
1997 Dorsey 45' Aluminum Citrus Trailer (A50121)
1997 Dorsey 45'...
2017 John Deere HPX615E Gator Utility Cart (A51691)
2017 John Deere...
