Satoh 650 G engine repair or re-power
   / Satoh 650 G engine repair or re-power #1
builder2
Bronze Member
Livingston county, Michigan
JD 5200 2 wd
I was given a complete 650 G by a friend who said it had a rod knock. It turns over fine.
Has any one ever able to get such as gaskets, bearings etc. from an auto parts store or had bearings cross referenced? Has any one ever put a different brand of motor in?
Is it worth fixing as parts seem expensive? Or is it better to part out?
Thanks in advance for any replies.
Paul
   / Satoh 650 G engine repair or re-power #2
Paul
Make sure it is actually a rod first...People jump to conclusions too quickly when it comes to tractor noises. If it is, then check the compression. If it is good, pull the engine, drop the pan and the bearing caps. See what is going on and move forward in a frugal manner. There is always the chance that you can simply replace the bad bearing and reassemble. Even if the crank shows some light score crocus cloth can work miracles!
Outlander,
That is along the lines I was thinking. Thanks for the input.
Paul
Case IH MXU110 (A50123)
Case IH MXU110...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2025 IR UNUSED Ripper (A53117)
2025 IR UNUSED...
2014 Ford Escape (A50323)
2014 Ford Escape...
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
2017 Chevrolet Silverado 3500 HD Crew Cab KUV Enclosed Service Truck (A52377)
2017 Chevrolet...
