Satoh 650 Bison PTO trouble
   / Satoh 650 Bison PTO trouble #1
quickhaul
I'm getting a knocking / rattling in my transmission when I engage the PTO with a load on it. Anyone have a suggestion will be appreciated.
Thanks,
Bobby
   / Satoh 650 Bison PTO trouble #2
I can think of two possibilities.
(the simple ones)
-A damaged/unbalanced shaft or U-joint is going.
(I have a joint going on mine and it makes 'knocking' type noises when I lift my blower up high with the 3-pt)
-The lock bolt that locks the PTO shifter onto the shift shaft has slipped out of place (or the dedent is a bit worn).
If that is the case (trial and error) loosten the lock bolt and reposition the shift arm.
It could be that while you believe that you are in 540 rpm you actually have most of 540 but are also catching a bit of the higher or lower gear as well.
To check that out , while pto is engaged and running gently move the shift lever back and forth just a little bit and see if the noise stops.
The distance you moved to stop the noise would then be the amount of correction you need to make in the opposite direction.
This also occured on mine.
Good luck!
Thanks for the input. Mine is definitely internal. Sounds like gear chatter. I know that noise will travel. The pto seal is leaking so I'll start there in case a bearing is bad. I've gone through several truck transmissions & differential, this will be my first tractor. Thanks for your reply !
Bobby
2004 Ford Taurus SE Sedan (A51694)
2004 Ford Taurus...
2019 Chevrolet Tahoe SUV (A52377)
2019 Chevrolet...
UNUSED FUTURE SB05 HYD BREAKER (A51248)
UNUSED FUTURE SB05...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
