Run into an unusual problem (I think) on my diesel Buck. Was trying to start it in some mildly cold weather (~25F) and had problems. At first it was as though the glow plugs weren't working. Then after a few tries, the starter stopped turning, and the oil and batt lights no longer came on when the key was in the run position. The key has a different "feel" to it as well, like it is not engaging the switch, in either direction. The tractor started just fine a couple of days ago (at ~45F).
I am thinking that the key part of the ignition switch is no longer engaged with the electrical switch part. That would explain the sudden lack of starter and no engine lights anymore in the run/on key position. Might also explain the hard starting earlier if the key was not really running the glow plugs.
Couple of questions from this:
Anyone ever run into this before?
Does the Buck have a separate electrical switch and key lock, or are they all one unit? And who might sell these?
As an immediate thing, can I just jumper a couple of wires and "hot wire" the tractor to run? I'm assuming that if I don't need lights, then once the tractor is running I really don't need any switch connections, that right?
TIA
TIA
