Sato 560 diesel
   / Sato 560 diesel #1
rocky10
gregoryrocky@juno.com
Im have proublems geting my injector pump to work , It checked out Ok at the shop, and I had new seals put in but now no Pump, and no ones got any info on this tractor
   / Sato 560 diesel #2
Did you bleed the system? Injector pumps can not pump air much less self prime.
Standard proceedure is to crack lines (or open valves) starting from filter all the way thru to the pump and I even crack the lines at each injecter 'till it spurts.
My current trick is to clamp shut the line coming out of my filter whenever I change filter elements thus saving all the bleeding process.
If you don't bleed, you can crank away 'til the battery is drained or the starter burns up.
   / Sato 560 diesel
Yes ive bleeded it out even put an elec pump on it , Nothing seems to work
2018 FORD EXPEDITION (A51406)
2018 FORD...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2009 KENWORTH T6 SERIES SLEEPER (A53426)
2009 KENWORTH T6...
