Shazbat
So I know I asked 5 years ago about a tractor for nearly 100 acres, and I appreciate the advice given, but that wasn't in the cards for us. (Never was able to get broadband)
Moving to a new piece of property in southern NH of about 20 acres soon with the following areas of tractoring need that I can see "right now":
1000ft of driveway to clean from snow and perhaps maintain, it's shared and the neighbors that share it are 800ft farther back but I believe they pay for someone else to plow in the winter now - however I need to be able to get out on my schedule, not the plow company's.
5-6 acres partially cleared starting to get overgrown, 80 ft elevation change from top to bottom (About 600ft in length), I would _really_ like to keep this mowed down for hiking and dirt bike trails.
Lots of deadfall that I'd like to drag to the house and burn.
Existing brush piles need to be moved and cleaned up.
Some internal roads, not sure of length.
1/4 acre of flat lawn (I'm not picky on a fancy golf course lawn so if a rough-cut mower could hanlde this, that'd be fantastic)
1/4 acre flat area that I'd like to put a garden.
1/2 acre of mostly flat overgrown area that I'd like to become lawn-like (See above).
The remainder of the land is heavily forested, and with the exception of maybe making small trails through it I would like it to remain as such. There are some existing internal roads that at one time were gravelled and taken care of, but I'm not sure of the extent as I've not been able to walk them due to not being properly dressed for the deer flies.
__________________________________________________________________________
After reading posts here until my eyes bleed, I'm thinking that again, a 30-40 hp tractor would probably handle 80% of my chores with a 2-bottom plow, back blade, FEL (of course) with a grapple, MFWD, and a rotary mower. I'm leery of going with a SCUT, even though I think it could handle all of my tasks (Albeit slowly) because of the ground clearance.
A front-mount snowblower would be ideal I think if I can swing it, but I don't think I can afford a factory hard-cab, so a soft cab may be an option there.
Dealers nearby from what I can tell are NH/Tym, JD(Two, but one only appears to have SCUT's on the lot), NH/Kubota, and Bobcat slightly farther away - I don't mind doing smaller services myself, but any major repairs I'd prefer to have someone more knowledgeable than me handle it.
Please let me know if I'm losing my mind or not =) thank you.
