Snow Attachments Sanding Help
   / Sanding Help #1
LedgeFarmer
Kubota L5740 HST Cab
I know we just finished winter, but it's never too early to start thinking about winter, right? I have about 1/2 mi of steep driveway that I need to sand/salt a dozen times each winter. I have a 60hp cab tractor with a snowblower to handle the snow. I'm thinking about getting a sander for this job. Has anyone out there ever mounted a hydraulic drive sander on the FEL? Thanks for the help.
   / Sanding Help #3
You could also use a PTO driven salt / sand spreader. We use one at work for sidewalks and it spreads wide enough for a driveway. Our hopper holds about 500-700 lb. and I'm sure would be less expensive than a hydraulic driven unit.
   / Sanding Help #4
Is there a reason why you would like to use a fel mounted spreader over a pto driven spreader? For about 1/4 the cost of a hydraulic ss type sander you could get a Herd 3pt sander. I think Herd got bought out by Kasco. I keep toying with the idea of buying a 750s, you probably could even get the next size up and put enough salt/ sand in it to do the whole driveway.
   / Sanding Help
The only reason to use a front mounted sander is to avoid taking off the rear mount snowblower to put the sander on. I also love the idea of not loading the sander by hand with the drive in type. Price will be the issue though, ouch! 4k? I think I'll keep shoveling by hand for a couple more years while I pinch pennies. Thanks for the advice.
   / Sanding Help #6
i use a 4n1 bucket to sand my drive. the biggest problem is the sand gets frozen when you need it the most but i would have the same problem with a sander :(
   / Sanding Help #7
Looks that way... Hope they dont wreck Herd's reputation. Looks like they killed the Herd model with the extra agitation designed specifically for spreading sand/salt (sry, cant remember the specific model number),maybe they didnt, but i couldnt find it on Kasco's website.
   / Sanding Help #8
Hello LedgeFarmer,
The issue of spreading salt and sand is not difficult with the right unit.
The hydraulic spin casters are very pricey and they require the flow of
the rear remotes as the front end loader hydraulics flow is too low.
The other issue is the need for a power beyond valve/priority vavle
for a front mounted spreader like this as a high volume remote valve
circuit for a snow blower attachment is what is required.
You will be money and aggravation ahead by purchasing the smallest
Vicon pendulum spreader with the salting/sanding spout attachments
or one of the larger units with the caster wheel attachments that
can be moved by hand easily, and can be loaded from ground level
easily as the hopper is very low when it is on the ground.
The Vicon Pendulum spreader is a non clogging spreader with a
cam arm agitator and the fiberglass hopper will not rust out on you either.
The Vicon Pendulum spreader alos has the ability to limit the spreading width
of the material that is cast out eliminating waste and overspread and allowing
you to spread more sand within a limited width aiding traction.
It will be much less money that the skid steer scoop spreaders as well.
If you mix your salt and sand together with a 1 pound salt to 10 pound
sand ratio you will have no problems.
The other option is simply to use less salt/no salt and pour windshield washer
fluid in the sand as you shovel it into the spreader and it will not freeze.
Using the windsheild washer fluid right out of the bottle does work for this very well.
I use sand and only sand and I keep the sand warm in a heated area and use only bagged sand
myself and have no issues with frozen sand but using the windshield washer fluid right
out of the bottle is something that works and works well with sand that is in a cold area as the alcohol
in the windshield washer fluid right out of the bottle keeps it free flowing.
I always use a kerosene fired salamander to heat everything up and it would work for your spinner spreader
to break up the clumps quickly.
   / Sanding Help
Thanks for the advice LeonZ. I'll definitely check those out.
   / Sanding Help #10
How much area do you need to salt?
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
2022 Heli Forklift (A51573)
2022 Heli Forklift...
2006 KOMATSU  D41P-6  CRAWLER TRACTOR (A52576)
2006 KOMATSU...
TRUCK FLATBED (A52472)
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
2014 Dodge 5500 4X4 Bucket Truck (A52748)
2014 Dodge 5500...
