Safest way to Park on slope with engine running???
   / Safest way to Park on slope with engine running??? #1
Anonymous Poster
Epic Contributor
Hi,
How do you guys feel about parking your tractor on a slope with the engine running? What is the safest way?
Sometimes this needs to be done. Like maybe if using a chipper or some other attachment that needs the pto turning. Sometimes it is just convenient to do so.
My tractor is a Kubota B2910 with HST. The parking brake is released if you push the brake pedal. I imagine if something fell on the pedal, or it was somehow accedently depressed, the brake would release.
If this happended and I had the gear range selector in neutral, the tractor would start to roll I believe. So I leave the tractor in gear and rely on the hst as a back up to hold the tractor should the brakes release for any reason.
I know with a gear tractor, under the same circumstances, the tractor would have to be in neutral. So gear tractor users must rely on thier brakes.
Logic tells me unless I am in need of using the PTO, when on a slope I should turn the engine off, but if I am stopping for only a couple minutes, like to put some cut wood on my loader or stones or whatever, I don't feel good about starting and stopping the engine multiple times every hour.
I guess my question boils down to my asking, when I park my tractor on a slope and get off it with the engine running:
* Should leave my hst in gear when stopped on a hill, and set the brake?
* Should I put the tractor in neutral and set the brake?
I guess to be absolutely safe I should [assuming I need the engine running]:
+Park at an angle to minimize drift if the brakes would release for some reason.
+Rest the loader or a tire against a tree or big rock?
+Lower the loader to the ground, and dig in a bit if possible
+Set the Brake
+Put tractor in neutral[to avoid possible engine driven movement]
+Chock wheels
What is the safest practical way to get off the tractor with the engine running on a slope?
Would highly appreciate any pointers...hopefully it won't be long until we in the north are all back out there in warm, sunny weather and I want to be as safe as possible!
   / Safest way to Park on slope with engine running??? #2
+Set the Brake
+Chock wheels
At the very minimum, do those three. For me to run the PTO with the operator off the seat, I have to put the range lever in neutral, then the shift lever in gear (the way I read it, this keeps the tranny lubricated and prevents overheating of the tranny oil).
Just make sure you always stay out of the path the tractor will move, it the chocks and brakes don't hold.
   / Safest way to Park on slope with engine running??? #3
Bill
I always set the brakes when I get off tractor with or without the engine running. The HST will only hold the tractor in place for a short time. Then it will start freewheeling if there is any angle to ground. I may not have the loader on, but as Roy said it will help to keep tractor in place also.
   / Safest way to Park on slope with engine running??? #4
Re: Safest way to Park on slope with engine runnin
I do most of the things mentioned, except chocking the wheels. I also turn the steering wheel in a safe direction. This is either to save me from getting run over or point it towards something like a tree so it does not keep on going or rolls into a ditch.
Of course the other thread about a person getting run over by his tractor twice will make me think a little more carefully about situations where it may be better to leave the steering wheel straight.
   / Safest way to Park on slope with engine running??? #5
I was putting in a septic system last summer on top of hill
for a new house.
The home owner was brush hogging w/ a nice 9n.
He stopped on top of hill put mower on ground and set brakes.
Left tractor running because of hot starting trouble.
I was digging and heard some noise and looked up to see him
running down other side of hill. /forums/images/graemlins/confused.gif
Later i went over and saw the TOTALED 9n.
Hit tree on front axle and grill area, broke axle,radiator,water
pump,transmission and many other parts. /forums/images/graemlins/frown.gif
The brakes weren't real good on tractor so they didn't help much.
What ever u do, DO EVERYTHING THAT U CAN TO KEEP IT FROM MOVING.
   / Safest way to Park on slope with engine running??? #6
<font color="blue"> The HST will only hold the tractor in place for a short time. </font>
I wish I had a picture of me running to catch my tractor as it was making it's way down the backyard heading for brush and an even steeper slope. The engine was off and the HST gave way (just as folks here on TBN say it will). It wasn't traveling very fast (thank goodness), so it was successfully saved from catastrophe. I learned my lesson. Parking brake engaged and implements down for sloped parking. Either one or the other will usually do OK for level parking. But, something should always be done. Extra precaution is always a plus, especially if the tractor is unattended or you need to be in a precarious position.
When I flew in the Air Force, we always chalked the wheels of aircraft when we parked. My personal experience with chalking has not been very satisfying though. For me at least, chalks will often skid along the ground. Sometimes they may work, but not reliably enough for me to count on them.
For you successful chalkers...what do you use for chalks?
The boxblade works great as an adjunct brake...usually better than my loader does!
OkieG
   / Safest way to Park on slope with engine running??? #7
</font><font color="blue" class="small">( For you successful chalkers...what do you use for chalks? )</font>
Well . . ., I generally call them chocks instead of chalks /forums/images/graemlins/laugh.gif, and I've used everything from rocks, bricks, blocks of wood, etc. to store bought ones. I think these from Camping World are about as good as any.
And when you talk about the chocks sliding, yep, some do, especially since you were parking those airplanes on hard, relatively smooth, surfaces; not quite the same as where you're talking about parking your tractor.
   / Safest way to Park on slope with engine running??? #8
Of course, chocks! The spelling correction is appreciated. I'm sure proper spelling is a sign of some greater good attribute. I think I was closer to it in 5th grade than I am now.
The chocks we used in the USAF, as I recall, actually worked pretty well. The personal experience I refer to was my own attempt at chocking in the driveway, etc. The aircraft chock profile was more or less similar to the product pictured in your link. They came in pairs connected by a length of rope. One each to keep the tire from rolling forward or back.
OkieG
   / Safest way to Park on slope with engine running??? #9
Those chocks in the link work really well. I used those with my boat and car trailer. The tire gets to roll over part of the chock creating down pressure so it doesn't slide. The driveway at my current house has a slope, no problems.
   / Safest way to Park on slope with engine running??? #10
</font><font color="blue" class="small">( … Safest way to Park on slope with engine running…? )</font>
Well, if you can at all possibly avoid it… Don’t park on a slope… running or not…
But if you must… park sideways… (if it’s too steep… then you shouldn’t be there in the first place…) not up/down, lower all implements into the ground, chocks should not be necessary… (and chocks could end up being the hazard, upon removal)
</font><font color="blue" class="small">( What is the safest way? )</font>
There really isn't "a safest way"...
Again, try to schedule your work on a level plane… instead of any slope… it's much safer… /forums/images/graemlins/smile.gif
2011 Crown Victoria Sedan (A51694)
2011 Crown...
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
BBQ Longhorn Bull Smoker (A51572)
BBQ Longhorn Bull...
UNUSED FUTURE FT-XJ7T 7 TON 46" HYD THUMB CLAMP (A51248)
UNUSED FUTURE...
