sabre 1742hs question
   / sabre 1742hs question #1
tpolley
i just inherited a john deere sabre 1742. what does the "reverse impliment option switch" do? the manual says how to use it but it doesn't say what it is or what it's for.
   / sabre 1742hs question #2
The short answer it allows you to shift to reverse with the mower deck engaged.
As the story goes, Once apon a time in Missouri two small boys were injured when the operator of a riding mower backed over them with the deck running. Following the civil court judgement JD added the RIO switch.
Before you backup, look behind you for obstructions, or pets, pull up on the RIO to the detent and then press the reverse hydro pedal. Once you are moving in reverse you can release the switch.
If you forget, no damage; just turn off the PTO and restart the engine.
2005 Nissan Pathfinder SUV (A55758)
2005 Nissan...
2014 Ram 1500 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 Crew...
Allmand Light Tower (Runs and Works) (A50775)
Allmand Light...
2011 Ford F-350 Knapheide Service Truck (A55852)
2011 Ford F-350...
1999 KENWORTH T800 DAY CAB (A54607)
1999 KENWORTH T800...
2011 New Holland B95B Cab MFWD Loader Backhoe (A55218)
2011 New Holland...
