SA424 Hood
   / SA424 Hood #1
MACflyer
Bronze Member
West Virginia
Yanmar SA424
Before I get too creative with the duct tape, does anyone know of anywhere to get used parts for these tractors?
My hood has broken, and the dealer quoted me $768 for a new one. Needless to say, I'm going to cobble it back together and then just have to manually pull the whole thing off anytime I need to get under it (the are supported by the gas strut will never bear any load again). Unless I could find a reasonably priced one to pull off a parts machine or something of that nature.
   / SA424 Hood #2
Just what broke????
The hydraulic lifts for a truck hood should work??
willy
   / SA424 Hood #3
How old is it? Dealer/Yanmar should replace free if still under warranty. Also would contact Yanmar directly if out of bumper to bumper warranty as they might replace free anyway since it's a common issue
   / SA424 Hood
Just what broke????
willy
No, the entire plastic shell broke unfortunately.
   / SA424 Hood
I bought it new almost exactly 2 years ago. I didn't know this was a common issue, but certainly makes sense given the flimsy design.
   / SA424 Hood #6
I would try using bondo or fiberglass to repair it
they have fiberglass kits with the glass matt
to make an easy repair
willy
   / SA424 Hood #7
My hood just **** the bed. 950 hours was all it could handle. I have a crack around the gas cap hole which is new but I’ve struggled with the screw nubs from the beginning. I will layer fiberglass & jb weld so i can get another 950 hours. 🤞
   / SA424 Hood
My dealer is going to replace it under warranty. It is definitely a poor design, the support screws are far too close together to support the weight of the whole hood. I only had 335 hours on it when it broke.
   / SA424 Hood #9
Wonder full news saves you a lot of hassle trying
to fix it your self
Somebody could have gotten the wrong hood to put
on your tractor
willy
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2012 Acura TL Sedan (A51694)
2012 Acura TL...
12ft Freedom Chip Body (A51573)
12ft Freedom Chip...
2009 Pontiac G6 Sedan (A51694)
2009 Pontiac G6...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
