S650G info
   / S650G info #1
lcorrell
Indiana
I just purchased an S650G with a national FEL and I'm looking for some info. I have searched here and learned a lot about these tractors. I also found the satohparts.com site and found some great info there. I found this tractor about a month ago at a dealer who said they don't check their used tractors out, they just put them on the lot and sell as is to keep the price down. I knew this tractor had a broken throttle, choke, and tach cable. They let me drive it around the lot and check everything out. It ran really well and made no bad noises. I decided to purchase the tractor and got it home yesterday. First thing, I fixed the throttle and choke cables. I then put it to work for about an hour leveling my gravel driveway. I started to notice the smell of antifreeze and decided to shut it down and check things out. It didn't seem to be overheating, but I could here gurgling in the cooling system. It looks like it was coming out the rad cap. So it could be a bad cap. Getting to the point, I found that the fuse for the idiot lights was bad. I fixed this, and found that the oil light stays on when the tractor is running! Since I have ran the tractor at the dealer for 15 minutes and at home for over an hour, with no bad noises, I doubt the oil pressure is really too low, but I want to check it out. Can anyone tell me what kind of oil pressure it should have? I will verify it with a mechanical gage. Can anyone tell me what the pressure rating should be for the oil pressure switch? If I know that - I could source a replacement sending unit at my local store.
   / S650G info
I put an oil pressure gauge on it. When I fired it up and the gauge jumped to 50psi I felt much better! Looks like it was just a bad sending unit for the idiot light. I still haven't figured out the gurgling in the cooling system. The next time I use it hard for a while I'm going to go over it with my infrared thermometer and see if I find any hot spots or anything. I guess I better start thinking about getting the manual.
   / S650G info #3
mine "gurgles" once it has been ran hard for a time. I also think mechanical gauges are a good thing, I just have yet to install some
   / S650G info #4
Hello - I just bought an S650G and was thinking that installing gauges would be a good idea. Not being much of a mechanic, I am wondering how to do that. Do you have any advice? Thanks.
   / S650G info #5
An oil pressure sending unit should be NAPA #OP 6075. A gurgling noise from a warm engine is normal for my S650-G.
   / S650G info #6
the lamp should come on when starting and go off while running so it is probally the oil pressure switch
2023 Bobcat T66 (A50120)
2023 Bobcat T66...
2002 Kendall 12ft Enclosed T/A Trailer (A50324)
2002 Kendall 12ft...
2011 TROXELL 130BBL (A52472)
2011 TROXELL...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-150...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
