Nov 1, 2015 / S550G #1 I Iron2259 New member Joined Nov 1, 2015 Messages 1 Location New Castle IN Tractor Satoh S550G Charging light will not go off.
Nov 1, 2015 / S550G #2 TBN Support TBN Support Joined Feb 4, 2015 Messages 4,561 Welcome to the forum. :welcome: I'm going to move your thread over to the Satoh section. Someone over there should have an answer for you.
Nov 1, 2015 / S550G #3 P PILOON Super Star Member Joined Aug 26, 2004 Messages 10,614 Location North of Mtl,Que,Can (Ste Adele) Tractor MT180D Welcome, Guess the tractor is telling you something, like the generator or regulator is faulty. When it wont start the problem will be confirmed. Check all fuses, grounds and connections as corrosion is most often the culprit. Good luck.
