I was mowing tall grass with a 4' brush hog yesterday and the Temp light came on, first I had ever seen it. No clouds of steam or dripping coolant, and the engine did not smell really hot. But stopped the tractor in place and went back to take a look this evening, it was near dark when I got home today, so I did not have a lot of time to do much.
First I checked the coolant level in the radiator, and it was down, missing about 1 qt. This was full about 6 weeks ago when I last checked. No obvious leaks at the hoses. Could not see the water pump well enough to say but nothing that stood out there as being wet. I refilled and ran for a bit with the radiator cap off. The top of the radiator got hot as the engine heated up, but I did not feel the whole of the fin area getting hot. But I only had time to run for a few minutes, so other than being able to say the thermostat opened some not sure I really learned much.
So I was thinking of going thru the basics on cooling before anything else. Flush the radiator inside and out (and back flush it too) with cleaner. Replace the radiator cap and coolant. Then try it again with some load and see how it does.
I had a few questions on the cooling system which I hope people here know:
1. What pressure cap? I've read everything from 9# up to 15# in various posts here. What's the right value? And does Napa or some other generic auto parts brand make one (I'd like to get this tomorrow)?
2. What's the total coolant capacity of the S470D?
3. I assume just regular green anti-freeze in a 50/50 mix. Or does this take some special coolant or additives?
Also curious, are the various radiator hoses still available? Anyone know the part numbers? It's probably time to replace them too.
And same questions on the thermostat and water pump. Are those standard parts or special for these Satohs? Hopefully won't need those but just in case.
TIA
TIA
