S373 clutch release
   / S373 clutch release #1
lmaulorico
overbrook, ks.
mitsubishi beaver
My S373 clutch pedal doesn't release unless manually pulled back. Clutch engages and disengages without grinding. Is release bearing bad? Or is there some lube point I'm not seeing. Any advise would be greatly appreciated.
   / S373 clutch release #2
This comes up now and then, even on my own 1450 (grey 373). The transmission input shaft is a little rusty and the clutch disc is not sliding as needed. This usually requires a split. When you split the tractor make sure you check the pilot bearing and release bearing and the clutch to see if anything needs to be replaced. Welcome to TBN!!
I was kind of afraid of that, thanks for the advice.
Kawasaki NR (A50324)
2023 INTERNATIONAL MV607 21FT ROLLBACK (A54607)
2023 INTERNATIONAL...
2 pair -st205/75r15 radial trailer tires (A53421)
2 pair...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A52377)
2019 Allmand...
2019 FREIGHTLINER SPRINTER 2500 CARGO VAN (A54313)
2019 FREIGHTLINER...
