S370D Beaver
   / S370D Beaver #1
iqzero
I have just purchased a Beaver. Came with a tiller in pretty fair condition and also a Flail mower. It was one that was left with a tractor repair shop for him to sell so I haven't met the previous owner. He forgot to leave the PTO adapter so I have ordered one. This machine has the anti-clockwise PTO but both of the machines are rigged to run that way.. The tractor has been used hard but still runs strong. I pressume that I will have to overhaul it after this season and would like to hear from anyone who has overhauled their own. I am an experienced mechanic/machinist and don't see that this machine is too complicated. I have located several places that have all of the parts that I will need. If I can get the job done with $500 or $600 dollars I will still have a bargain tractor which should be sufficient to keep my grounds and garden maintained.
   / S370D Beaver #2
If It runs smooth and with power why rebuild. does it make blue smoke or some type of noise to indicate a problem.
   / S370D Beaver #3
in my continuing quest to find a PTO adaptor for a B6000,
may i ask how much one for your beaver was, any photos?
thanks
   / S370D Beaver
One of the cylinders is a little weak. When I am cold cranking it, ine has a little less compression than the other. As it warms up they both are pulling but I am sure that one has less compression.
   / S370D Beaver
I ordered the PTO adapter from Sheaffer's You will find their email address on several of the posts and also their phone number. The cost was $65.00
   / S370D Beaver #6
I had s similar ting on my 3 cyl. one of the injector line yas a little lose and seeping fuel. not a leak really but just enought to cause lose of power when starting or when under full power
   / S370D Beaver #7
The PTO adaptor does not correct the rotation, just changes from a small spline to the standard spline size. Valley power has the PTO reverser, it is something like 400 bucks.
   / S370D Beaver #8
Do you have any contact information for Valley Power? I may be interested in the PTO reverser.
Thanks!
   / S370D Beaver #9
Look at the post by texo on the 650 g. They posted a reply with a phone number.
   / S370D Beaver #10
Call Bill at 1-800-609-5110, Valley Power Products (satohparts.com) They sell parts and manuals for Satoh/Mitsubishi tractors. 540-345-9650
2013 BMW X5 xDrive50i AWD SUV (A50324)
2013 BMW X5...
EZ Flow Gravity Wagon (A50774)
EZ Flow Gravity...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2023 Third Coast Equipment RA12H Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2023 Third Coast...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
