techwrtr2
Platinum Member
Finally got around to putting a new battery in the Beaver today as I've gotten tired of having to jump it when cold. To my chagrin, it doesn't want to start. Got great cranking speed thanks to the new battery, but no fire. It's actually behaving like it's out of fuel. It has a half tank.
I cracked the lines at the injectors and while things are damp, there was no appreciable fuel in the lines. I moved up stream to the fuel filter. Fuel in and out. I opened the bleeder valve on the injector pump, and fuel comes out there too.
This leads me to believe that I have an injector pump problem. Which does baffle me some since it has been running great other than the battery issue and it was running fine when I last parked it.
Before I dismantle it and try to either find a replacement pump or somebody to rebuild this one, anything else I might want to investigate or test?
This puts me in a bind because I have wood to split (lots of wood to split) and the Beaver is my power source for the splitter.
