S3010 problem
   / S3010 problem #1
burntclutch
North East Louisiana
LS s3010
I have a 3010 with the s4l series engine
After a couple hours of run'n (bush hog'n)
If the tractor lugs a little it takes a while to recover and get back to pto max rpm
If I idle down any at all the engine will die
After setting for 5-10 min it's good to go again.
I have searched the forum to no avail
I have good filters
I have blow'n air back through my fuel line from tank to filter
I have cleaned my tank
What next?
Any one with an idea of where to look next?
   / S3010 problem #2
air filter?
   / S3010 problem
air filter?
All my filters only have about 6hrs on them from last service.
And I allways blow out my air filter as part of my pre"trip" routine before it gets worked hard for several hours.
   / S3010 problem
I think I found the problem
And embarrassed to say what I think the problem was,,,
It's warm'n up now to cut 7 acres,so I'll know in a couple of hours if I fixed the problem, probably would Have saved myself alot of headache if I would Have remembered to do this the last time I serviced it! Guess I was rushing for some reason?
2016 Mercedes-Benz GL450 4MATIC AWD SUV (A50324)
2016 Mercedes-Benz...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51572)
IMPORTANT PLEASE...
UNUSED FUTURE HYD HOSE BUNDLE (A51244)
UNUSED FUTURE HYD...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
(2) ROCK GUARDS FOR 2022 FORD BRONCO (A51244)
(2) ROCK GUARDS...
