S3010 Factory Rear Remotes Photos
   / S3010 Factory Rear Remotes Photos #1
dkhntr04
Northern MN
Deere 3720 Cab
I am going to add rear remotes to my McCormick CTV28 (S3010) and would like some pictures of the LS rear remote kit. Primarily of the valve and valve location, rear coupler mounting, and where the valves are attached to the hydraulic system. i am trying to decide if I would like the LS kit and if it would fit up with the minor differences between the two machines, or if I should go with the build it yourself approach. Thanks for any input!
   / S3010 Factory Rear Remotes Photos #2
I installed the single LS OEM rear remote kit on my S3010 in December 2010 and discussed some aspects of the experience here:
S3010 Rear Remote Thread in Hydraulic Forum
There is only one picture showing the rear remotes and hydraulic top link. The valve and lever is under the right side of the seat and easy to operate. I'll look to see if I have any more pictures for you. I would think you could contact LS to see if the same kit would work on your Montana.
   / S3010 Factory Rear Remotes Photos #3
I found the instructions that came with the single remote kit I installed last December and scanned some of them for you if you are still interested:
View attachment S3010 Single Rear Remote Kit.pdf
Sorry, they came out a little washed out.... If you still want pics let me know.
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2012 PETERBILT 388 WINCH TRUCKS (A58214)
2012 PETERBILT 388...
CFG Industrial MH12RX (A56469)
CFG Industrial...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A56858)
2012 Mack CXU613...
