S185 Shutting down after 2 minutes
   / S185 Shutting down after 2 minutes #1
Larry767
Humboldt, SK
Looking for suggestions. I have an S185 that started shutting down randomly last year. When it shuts down it is as if a key is turned off. Unlike other problems I've read about, this skid steer fires right up after it stops. Even more curiously is that since I started trying to troubleshoot the problem I have found that it is consistently running for about 2 minutes, then shutting off. We just tried replacing the fuel shutoff solenoid with a brand new one but the machine still ran for 2 minutes and shuts off. This unit has the electronic control panels in the cab (no key). When it shuts off the control panels go dead. One possible clue is that the left panel that has the gauges and hour meter appears to have moisture inside - the hour meter LCD is clouded over and unreadable. If I remove that panel will the machine still run? Do I need to jumper one or more of the connectors in order to bypass something? Any thoughts appreciated.
   / S185 Shutting down after 2 minutes #2
Do no jumping. You can can fry an expensive controller. I would try the "switched power" relay first.
2013 MACK PINNACLE CHU613 DAY CAB (A50854)
2013 MACK PINNACLE...
12 FLATBED W/ PRESSURE WASHER FRAME (A50854)
12 FLATBED W/...
F-500 POWER PUMP 500HP TRIPLEX POWERED BY 3412 CATERPILLAR ENGINE (A50854)
F-500 POWER PUMP...
2003 MACK RD6885S T/A DUMP TRUCK (A51406)
2003 MACK RD6885S...
Case 830 Tractor (A50514)
Case 830 Tractor...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
