s 650 g satoh
   / s 650 g satoh #1
kimokuley
can someone tell me if the hydraulic oil universal type sold at TSC is ok for my s 650 g satoh ? Iam having trouble with my hydrualics could it be too thick? If not what is the best way to get the air out of the lines? Thanks for your help. Kim
   / s 650 g satoh #2
there are a lot of people that would like to help with your hydralic problem. the trouble is you did not say what the problem is .is there a loader on the tractor? is the hydralics slow ? is it not lifting the weight? ect.what did you do to try to fix it? did you clean the filter? strainer.the oil or fluid most likely is not the problem unless it is contaminated and turn into sludge.
   / s 650 g satoh
i am sorry that i didnt explain myself better. I have just found out that the pump was backwards so I flipped it over and now i have pressure I can see the lines jump but my 3 pt still doesnt work. will the air work its way out or do i need to do something like bleading the lines? It does have a front end loader but i dont have it at this time, I need the hydrualics to work so I can go and get it. Would welcome any and all help. Thanks Kim
   / s 650 g satoh
had pump off of front and found that it was on backwards from previous owner, is their a secret for getting all the air out of the system? I can watch my llines move when the lever is moved but my 3 pt doesnt move. I have a front loader for it but cant get until I get my hydraulic working any help would be very much appriciated. thanks Kim
   / s 650 g satoh #5
HOME DISCUSSIONS PHOTOS REVIEWS CLASSIFIEDS DEALERS STORE
Direct ship used program tractors at low prices.
CARVER KUBOTA DEALS. Click Here.
Main Index | Search | My Home | Who's Online | FAQ | Log Out | Mark All Read
TractorByNet.com > Brand Specific Forums > Mitsubishi/Satoh
how to trouble shoot 3 point hydralics
Show Recent Threads:
24 Hours
Since My Last Visit Welcome, mit.
You last visited: 05-29-2009 at 09:17 PM
Private Messages: Unread 0, Total 3.
Search Forums
Show Threads Show Posts
Advanced Search
Quick Links
Today's Posts
Mark Forums Read
Open Contacts Popup
Networking
Contacts
User Control Panel
Edit Signature
Edit Your Details
Edit Options
Miscellaneous
Private Messages
Subscribed Threads
Your Profile
Who's Online
Go to Page...
Page 1 of 3 1 2 3 >
Thread Tools Search this Thread Display Modes
05-24-2007, 07:40 PM #1 (permalink)
mit
Posts: 301 how to trouble shoot 3 point hydralics
can any one help with trouble shooting a 3 point hitch hydralics system.lets say 1. there is fluid
2. the fel hose is connected on the hydralic line.quick connectors.
3. with the engine started and the lever moved to the up position it does not lift.
what to check next?
mit
View Public Profile
Send a private message to mit
Send email to mit
Find More Posts by mit
Add mit to Your Contacts
05-24-2007, 10:45 PM #2 (permalink)
JerryG
Super Member
Re: how to trouble shoot 3 point hydralics
I have learned over the years that the first thing to check when having a hydraulic problem is always the quick disconnects. They can look like they are connected and not be. Some times you have to take them apart and put them back together to find out that they weren't together right to start with.
__________________
My Photos
My OTHER Photos
JerryG
View Public Profile
Send a private message to JerryG
Find More Posts by JerryG
Add JerryG to Your Contacts
05-25-2007, 06:10 PM #3 (permalink)
tractorErnie
Veteran Member
Posts: 1,523 Re: how to trouble shoot 3 point hydralics
Mit, Im willing to help you if you call us, otherwise I type like a turtle.
I have trouble shot a few mitsus that would not lift
you can find us at
Used Yanmar tractors, New Mahindra tractors, New Branson Tractors from Ernie's Imports inc
Ernie
tractorErnie
View Public Profile
Send a private message to tractorErnie
Find More Posts by tractorErnie
Add tractorErnie to Your Contacts
05-27-2007, 02:48 PM #4 (permalink)
mit
Posts: 301 Re: how to trouble shoot 3 point hydralics
i have in the hydralics jd20 fluid. it is full. i tried air pressure at the rear vent hole with tractor on and off while working the lift lever back and forth. it still will not lift. i opened the pressure relief valve that is near to the gear shift and crank the engine. fluid came out of one of the holes. i blow out the pressure relief valve with 100lbs air so it is clean. put it back together it still would not lift.any help would appreciated.
mit
View Public Profile
Send email to mit
05-27-2007, 02:55 PM #5 (permalink)
mit
oh i took off the quick disconnects and blew air through so there is no restriction all the way to the pressure relief valve. i think that the pump is fine cause i put my thumb over the hole while cranking and it blew fluid .i dont know what else to do. i was told to change the fluid to a thicker oil but i dont think that is the problem.
mit
View Public Profile
Send email to mit
05-28-2007, 08:49 PM #6 (permalink)
wushaw
Elite Member
Posts: 2,828 Re: how to trouble shoot 3 point hydralics
Well there is one thing you can try is take the top of the three point housing off to see if it has a frozen piston or broke piston. I am grasping at straws here ....although on my 372 the 3pt would not come down once and it turned out the piston was froze in the up position.
wushaw
View Public Profile
Send a private message to wushaw
Send email to wushaw
Find More Posts by wushaw
Add wushaw to Your Contacts
05-28-2007, 09:37 PM #7 (permalink)
mit
i blew air into the hydralic line. the line that carries fluid to the control valve and the lift piston. i can hear the air gushing out.there is no back pressure.its like if the pressure is diverted from the piston. i have read that the control valve could get stuck in a neutral position.in this position the pressure or oil gets dumped back into the resovour.
mit
View Public Profile
Send email to mit
05-29-2007, 02:45 PM #8 (permalink)
wushaw
Elite Member
Control valve stuck in the neutral position sounds like it could be.
wushaw
View Public Profile
05-29-2007, 09:36 PM #9 (permalink)
mit
i pulled off the reservoir and took off the control valve. i blew air into one of the holes and it is coming out of the poppet valve discharge outlet with any position of the control lever.i unscrew the poppet valve.the big nut with no hole and remove the spring and the piston. the piston was a little tight to come out i found a piece of crud on it. i cleaned and replace poppet valve,spring and tighten down.then i air tested .when the control lever is pushed in air comes out the second hole and when released the air comes out of the poppet valve discharge.dont know if it will work on the tractor as yet but it seems to be working the right way now.thank you all for your help.
mit
View Public Profile
Send email to mit
06-06-2007, 10:35 PM #10 (permalink)
mit
so my 3 point hitch works. it goes up and down and all the in between positions.do any one know how to make a home made carry all to attach to the 3 point hitch?made from wood and bolts?
mit
View Public Profile
Send email to mit
Page 1 of 3 1 2 3 >
Message
Cancel Changes
Quick Reply
The following errors occurred with your submission
Okay
Message:
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Options
Quote message in reply?
Posting Quick Reply - Please Wait
ォ Previous Thread | Next Thread サ
Thread Tools
Show Printable Version
Email this Page
Subscribe to this Thread
Display Modes
Linear Mode
Switch to Hybrid Mode
Switch to Threaded Mode
Search this Thread
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may post attachments
You may edit your posts
BB code is On
Smilies are On
code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
User Control Panel Private Messages Subscriptions Who's Online Search Forums Forums Home General Forums Buying/Pricing/Comparisons Owning/Operating Parts/Repairs Attachments Customization Build-It Yourself Hydraulics Projects Safety Oil, Fuel & Lubricants Trailers & Transportation Kubota Kubota Buying/Pricing Kubota Owning/Operating John Deere John Deere Buying/Pricing John Deere Owning/Operating New Holland/Ford New Holland Buying/Pricing New Holland Owning/Operating Kioti Kioti Buying/Pricing Kioti Owning/Operating Mahindra Mahindra Buying/Pricing Mahindra Owning/Operating Massey Ferguson Massey Ferguson Buying/Pricing Massey Ferguson Owning/Operating Brand Specific Forums Yanmar Power Trac Cub Cadet Zetor, Century & Branson Case-IH Montana TYM Toolcat Mitsubishi/Satoh Iseki Bobcat Tractors McCormick All Other Brands Chinese Tractors Grey Market Tractors Related Equipment Lawn & Garden Construction Equipment Ag Tractors & Machinery Vintage Tractors ATVs & Utility Vehicles 2-Wheeled Tractors Regional Forums Northeast Midwest & Great Lakes Mid-Atlantic & Southeast The South Northwest West Coast & Southwest Canada Other Forums Rural Living Photos Related Topics Family and Friends (Announcements & Notices) New Member Introductions News/Feedback Sister Sites CountryByNet.com Horses / Equine (HorsesByNet)
Contact Us - TractorByNet.com - Privacy Statement - Top
Terms of Use | Privacy Policy | Advertise | ゥ 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.21612 seconds with 10 queries
   / s 650 g satoh #6
first i would try and see if the front end hydralic hoses are coupled together.if it is not couple it together and then try the 3 point lift.fluid may not be going to the lift cause the loader is not connected and the hoses coupled together. if that dont work you have to verify that fluid is getting to the 3 point.
   / s 650 g satoh
Hey everyone thaks for all the help!! yesterday I had the afternoon off and I tuned the old girl up new wires new plugs, set the timming and she ran like a top when i got the rpms up i noticed a squeeling from the pump so i too a wrench and held the ball in on the female hose end and got alot of air and dark fluid and then hot fluid and then put the hoses together and low and behold the darn thing started working, so when and got the fel and everything is good, Thanks again to everyone. Kim
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
KSI Conveyor (A53472)
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2020 Nifty Lift TM34TG (A51573)
2020 Nifty Lift...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
