S-373 how do I ck fluid levels ?
   / S-373 how do I ck fluid levels ? #1
vetter
I just bought a little S 373 Mitsubishi and the 3-point doesnt always go up and I am thinking maybe the fluid level can anyone let me know where to ck the level there is no dipstick that I can see and was also wondering if this has the gear oil or what needs to be in it and how much any help would be greatly appreciated
Thanks for the info I will give it a try and see what happens
Appreciate all the help
Jim
   / S-373 how do I ck fluid levels ? #4
you remove that bolt and the hydralic fluid should be to that level.if you have enough fluid and you think the filter screen is clogged you have to drain the fluid in a container and wash the filter screen with parts cleaner.
   / S-373 how do I ck fluid levels ? #5
good info, folks. my "shop manual" is not too comprehensive for my purposes. is this reservoir also the one for the hydraulics? if not, any clues as to how to check the levels and fill/drain for those hydraulics?
thanks---
thom d.
   / S-373 how do I ck fluid levels ? #6
the fluid you put in the resorvoir will depend on whether you have a fel.(front end loader.)some tractors have a seperate resorvoir for hydralic fluid.while others have one thats for the hydralic and transmission fluid.read the material on the posted site it has most of the answers there.Valley Power
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2007 Mack 600 Day Cab Winch Truck (A53117)
2007 Mack 600 Day...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
2016 KENWORTH T680 TANDEM AXLE MID ROOF SLEEPER TRUCK (A53426)
2016 KENWORTH T680...
