My rzt has progressively lost the ability to go up any type of grade= no power from the drives. It will go up a slight incline if you give it about half of the arm travel (drive speed). I was going to change the fluid only to realize there is not a drain plug on the drive only a vent on top I tried to pump the fluid out
after seeing what I was dealing with, even stood it up on its end but no fluid came out and both drives are spotless. No leaks. Added some 20w50 to drive through vent but not sure how to be sure fluid is going from trans to hydo side, air entrapment etc. It seems like it is a fluid problem because it drives just a little better when cold.HELP please?
