RX 7320 Diagnostic codes electronic pedal clutch not disengaging dealer far away
   / RX 7320 Diagnostic codes electronic pedal clutch not disengaging dealer far away #1
kinghomes
huntsville
John Deere 6300
Anyone know how to pull codes . I know they can be pulled manually. Also, if I can figure how to pull, anyone know how to read? Anyone know how to get hold of cable and software? Anyone know anything about the proportional electronic foot pedal clutch. Closest dealer to me is one hour. He is very busy and will not do house calls. So it is one of those bring it to me me will get to it when I can. Oh and by they way leave a blank check because I am so busy my time is very very expensive. I don't want to burden the overloaded technician. And it will take me a total of 8 hours to load unload load unload connect trailer disconnect trailer wait wait wait. dare say logistics will burn 10 hrs of my time. Kills me when I could hook a diagnostics software and diagnose myself in 30 minutes But, hey they want to make sure the service dealers earn a living. Too bad because I want to earn a living too. For the dealer to earn his fee I have to work for 10 hours for free!!!!!! Thats the part that burns my .....
My electronic pedal clutch is not disengaging clutch.
I sympathetic Kioti dealer helped me with the clutch position sensor calibration. Clutch working fine now. My d dealer wanted me to spend 10 hours plus with drop off and pickup later. How could they do that? Leave it through the holiday, let my hay bake and then put a big Bill on me for a 3minute no tool procedure.
   / RX 7320 Diagnostic codes electronic pedal clutch not disengaging dealer far away #3
People need to make it perfectly clear to their dealer or anyone else they do business with how they feel about what is being offered to them.
   / RX 7320 Diagnostic codes electronic pedal clutch not disengaging dealer far away #4
Glad to hear you were able to fix this easily and without wasting 10 hours. Is the fix something you can share/post in case others run into this issue?
Clutch calibration : shuttle shift in forward; left brake set on ; Ignition on ..... press (inc.+) button(button on right cab pillar) until light on dash (I think the N button) flashes; release (inc +) ; fully depress clutch and hold ; press (dec -) button (same button on right pillar) light blink on dash means full down registered; remove foot from clutch then press (inc +) light on dash should blink confirming clutch all out registered. ..... Turn switch off .... all through all done.
I have found many do not appreciate constructive criticism. But I told the guy how tough it was for me to do a drop off. I offered to bring it to him but he said I had to leave it because he is so busy and can't stop to pull codes. And that he works all day and all night. Business is good. Good for him bad for me.
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
UNUSED CFG INDUSTRIAL MX50R EXCAVATOR (A51247)
UNUSED CFG...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2013 GMC Yukon Denali 4x4 SUV (A51694)
2013 GMC Yukon...
KUHN GMD-310-HD LOT NUMBER 38 (A53084)
KUHN GMD-310-HD...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
