RV's - the sequel: Powerless
   / RV's - the sequel: Powerless #1
Wingnut
Veteran Member
Mid-Michigan
Kubota L3710 GST
RV\'s - the sequel: Powerless
OK folks, get your thinking caps on and give me a clue ... 'cause, as many of you know, I'm clueless.
Finally got the generator running properly on my mini-winnie ... but I'm feeling pretty powerless. After finding no power inside ... I got out the meter and checked the outlet box in the rear ... which is supposedly where the generator sends the generatee (electricity) ... and measured about 12-12vac ... which seems to be about 10% of what I'd expect.
We're talking a 2.2KW Kohler generator designed for RV's.
I've checked the reset switch on the genset ... made sure that the revs are high enough to put out juice ... but no joy in mudville tonight.
What whould I be looking at / for / etc??
too bad that common sense ain't
   / RV's - the sequel: Powerless #2
Re: RV\'s - the sequel: Powerless
Is the generator running at rated RPM? or is it running at an idle? If its at its operating RPM, sounds like the regulator. (Could just be a loose wire) Without a wiring diagram. . . . I would just be guessing.
Steve
   / RV's - the sequel: Powerless #3
Seems I had a buddy who's generator/welder wouldn't output. Turned out it was the magnets in the generator part. He called the manufacturer and they told him after the unit has set for awhile the magnets needed to be re-energized (still sounds like BS to me). Anyway, they sent him a replacement set of magnets that they said eliminated the problem. He dropped them in and sure enough it worked.
SHF
   / RV's - the sequel: Powerless #4
My 6KW has a wound field controlled by a regulator, not perminant Mags, so that could be his problem, but like I said before, without a diagram, it's just guessing.
Steve
   / RV's - the sequel: Powerless #5
Wingnut, where exactly are you measuring the voltage at? There should be a thirty amp breaker right on the genset. This breaker is sometimes right in front of the genset on other models it's on the side and very hard to see. Make sure it's not tripped or turned off. Twelve volts sounds like your only getting neutral votage feed. Just a guess.
Another thing that is easy to check is the brushes could be dirty. These are just guesses.
On your unit do you have to plug the 110 shore power plug into the genset plug to get power feed from the genset? Is that were you were checking power.
Throw alitttle more info out might be able to help more
tough to trouble shoot electrical problems over the net.
One other thing that is very important if you have messed with the governer or the carb settings you could end up putting out way too much voltage. So make sure that before you power up anything in the Rv make sure that your putting out 126-132 volts no load with about 63 hz.
Gordon
Gordon,
the genset has a reset breaker on it ... checked that .. it was "on". The genset power terminates at a receptacle in the back compartment where the trailer power cable is. The shorepower cable connects to 110 ... or into the genset receptacle.
I tested the receptacle ... and then unscrewed the receptacle from the box and tested the wires at the connection to see if it was the receptacle that was bad.
Heven't touched the genset settings (carb or governor) at all as I didn't want to make anything, that was wrong, worse.
Brushes ... good thought ... never though of that
thanks for the feedback
yeah, I thought of the loose wire too ... but if it is, I'd guess it has to be inside ... the book only has an external wiring diagram ... guess they want to keep their techs in business.
OK ... we're down to resistor, stator field, broken or loose wire...
guess she's gonna wait until I get back from the Texas trip .... good thing I got the inverter to keep the laptop chugging ...
thanks guys!
   / RV's - the sequel: Powerless #8
How's the lights and gauges working? Did you get them fixed?
SHF
   / RV's - the sequel: Powerless #9
If you don't already use one of those surge protectors(I use one of the 6 plug type for home use) with your inverter.I would recommend you get one.One of our company trucks (98 EXplorer) alternator went bad and took out the inverter and a surgeprotector.My old company truck also an explorer simply surged (this may have just been the inverter)and took my surgeprotector. Saved the laptops and other equipment though...Who knows how much it would cost would be to replace a laptop power supply...?
Good luck with the generator...
Lil' Paul
Proud owner of TC21D
Laziness is the Father of invention.../w3tcompact/icons/laugh.gif<P ID="edit"><FONT SIZE=-1>Edited by PBurns on 06/21/01 08:57 PM (server time).</FONT></P>
   / RV's - the sequel: Powerless #10
Now go a step back and check the voltage at the connection box right in the generator compartment and see what type of reading you have there. Bad connection is still possible. also check the pole output voltage and that will tell you what is what.
Gordon
2020 Freightliner M2 106 Elgin Street Sweeper Truck (A55852)
2020 Freightliner...
2021 CHEVROLET SUBURBAN (A53843)
2021 CHEVROLET...
LOT LOCATIONS (A56129)
MURRAY PUSH MOWER (A55745)
MURRAY PUSH MOWER...
2022 BOBCAT T770 SKID STEER (A52706)
2022 BOBCAT T770...
