RV dump on old septic system
/ RV dump on old septic system #1
charlz
Elite Member
Meridian Idaho
Kubota B7100D
I recently purchased a used 'Fun Mover' which is a Class C RV with a garage in the back for our dirtbikes :thumbsup: Guess I didn't have enough things to work on or spend money on :D
I have an old septic system at the far end of the property that used to service the original owners trailer. I am thinking of using this system as a home RV dump. Nothing is attached to the system (tank and drain field), just two old pipes that come out of a Y right off the septic tank. I am working on extending the one line to a spot where it would be convenient to park and dump the RV. Am I correct in thinking I should turn the other pipe into some type of vent? extend it above the ground with a 180 and some screen or something on it? My thoughts are this would be good because 1) the displaced air needs someplace to go when the sewage pours in during the RV tank dump... I probably don't want the RV hose 'burping' and maybe popping off/out 2) there should be a vent in the system anyway to prevent any pressure build up etc. in the septic tank (the pipe going to the RV dump port will be capped when not in use).
Thoughts?
/ RV dump on old septic system #2
This is done all of the time and any adjustments in dump rate, etc you will figure out with time.
You may want to check out threads on www.rv.net on the subject too.
You sure will have a fulltime project now that you own a MH. :D
/ RV dump on old septic system #3
Correct. I'm also pretty sure the RV tanks are vented, and if your dump pipe is larger than the hose, it will self vent to prevent "gurgling"
/ RV dump on old septic system #4
You want the pipe going to the septic tank vented but not the tank itself. A septic tank functions antirobic ( without oxygen) the leach field fuctions aerobic ( with oxygen). Since you aren't going to be using it daily, a dose of some brand of bacteria every now and then, would also be helpful, Bio Clean , Robic, etc.
Yep, been reading over there like crazy :D I have seen where people put in extra piping at home for an RV dump but usually it is to an existing system, that is likely vented through existing vents on their house.
So is there some rule of thumb on how far away from the tank to keep a vent? Right now the second pipe ends about 7 pipe-feet away from the tank. Would it be better to extend this at/above ground level and put a cap on it? Then open the cap for venting when dumping but otherwise leave the system closed? Or just go ahead, extend it and make it a permanent vent?
Good idea!
Thanks everyone for the feedback so far!
/ RV dump on old septic system #7
Just for your information in case you don't already know it;) . . . Lots of RVers put chemicals in their holding tanks to help break down solids and prevent odors. Places that sell RV supplies and accessories have chemicals specifically for that purpose. Some (not all) of those chemicals will kill the anaerobic bacteria. In other words, they stop the normal functioning of a septic system. So first, if you use such chemicals, try to get ones that won't do that, and second, consider adding bacteria, as recommended by Kays Supply.
And if I'm telling you something you already know, sorry about that.;)
I have read lots of 'black tank' posts over on RV.net but no worries on mentioning it here ;) I plan on using the 'natural odor control' additives which I believe are just a large dose of the good bacteria. Need to double-check that and select a product to buy. The formaldehyde products are supposed to be much better at odor control but those are the ones that kill off the bacteria and are bad for septic systems. We will see how it goes.
/ RV dump on old septic system #9
Doing this does not require any "overthinking" of the issue. Just do what you stated in the first post. :D
We use the cheap bacteria stuff (like we use for the septic tank at home) from the Dollar General to start to predigest the stuff when on the road by putting it into the black tank before we leave the house in about a gallon of water so the tank is not dry on the bottom at first usage.
Beware www.rv.net is like any other forum. Only about 10% of what you read is valid. If you know the 90% not to read you will be just fine. :)
/ RV dump on old septic system #10
I'm lucky that our duplex is on city sewer and we had made a cleanout toward the front. Never thought about a motorhome at that time but it will be an ideal place to dump the tanks.
/ RV dump on old septic system #11
charlz, a larger cap than the pipe will automaticly let air out of your #2 pipe w/o blowing it off fwtw.
I use an old septic on my property when I cant find a dump station when I pull out of a camp spot and/or it didn't develop a leak on side of a dirt road somewhere along the way home. ;)
I just lay the hose into it and let er rip no fancy hook up just open the lid plenty of air space its handy to have a water hose right there too. Btw dump black then gray in case they didnt mention that?
Steve
/ RV dump on old septic system #12
Most tanks around here are vented, if yours is, I wouldn't sweat it...We add bread yeast, seems to work well...
/ RV dump on old septic system #13
Closing the vent when not in use would be fine. It could stop a problem with animals and younguns. All the other info posted sounds like good advice.
/ RV dump on old septic system #14
Steve
We like to fill the commode to the top and dump it fast a few times if we still have water onboard when we dump. It really gives a blast to any remaining past actions.
The GD bacteria use before you use it is more important when an accidential leak on the side of a dirt road may occur and it is great for a septic tank dump too.
/ RV dump on old septic system #15
Yup agreed Gale, camping sometimes is a lot of improvisation at times and having a little knowledge ahead of a situation is helpful I think anyway.
I thank my RV friends for what wisdom they passed along when we became RV'ers. :thumbsup:
Steve
2021 JCB 35Z-1 Mini Excavator (A61572)
2021 JCB 35Z-1...
John Deere 1025R (A62177)
John Deere 1025R...
2017 Caterpillar 349FL Hydraulic Excavator (A61572)
2017 Caterpillar...
1989 Corvette Convertible (A61574)
1989 Corvette...
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
LOOK! (A63116)
LOOK! (A63116)
