JMER817
Platinum Member
Ok, I know this isn't a typical topic on this site, but most of you are like me, use common sense, and I value your opinions. I have a 2004 27' Jayco travel trailer which uses 30 amp service. I installed a 30 amp outlet at my home so that I can plug into and have full power and use of the unit. We are going to take the trailer down to a friends house for the weekend soon and will be connecting to a 20 amp circuit (outlet). (Friend does not have 30 amp service availabe) I have searched the internet and get various opinions on whether I can use the air conditioner during this time. The air conditioner is a rooftop RV Product 8000 series. The only thing that the manual says about power is that it was designed to run from a 115 VAC, 60 HZ, 1 phase power supply. The breaker in the trailer for the AC unit is 20 amp. I could not find the amps used under full load anywhere, but comparing similar newer units appears to be in the 12-14 amp range. The power cord for the trailer is 20' long. I feel that as long as I use my 10 gauge 25' extension cord, and don't run anything else (ie:fridge, microwave, tv, toaster etc) that I should have no problem running the AC. Your thoughts??
