Mowing Rustproofing mower decks
   / Rustproofing mower decks #1
bfabricant
I recently purchased a B7510 with a 60" belly mower, and friends have suggested undercoating the mower to protect it from rusting. I am wondering if anyone has done this, and if so what effect it has on discharging grass, as undercoating is not as slippery as the current painted surface. Thank you in advance for you input.
   / Rustproofing mower decks #2
Welcome to the forum.
Do your friends have mower decks that this has worked for them?
I am thinking not, but curious as to their experience.
   / Rustproofing mower decks #3
I have a BX1500 w/48" mower deck, 200 hours. At the suggestion of my K dealer I used Fluid Film Rust&Corrosion Preventive when I put the deck to bed last fall. The underside of the deck was showing a lot of bare metal and my experience has been that once the paint is gone it's gone forever (goes for snowblowers too). Came Spring, this stuff was there just as slimy and ugly as it was in October and looks about the same in June. I seem to recall from Internet searches it is a "woolwax" product.
Don Sullivan, NH
   / Rustproofing mower decks #4
I saw a guy on a lawn care TV show recently who recommended including this in your yearly maintenance. Turn deck over, remove & sharpen blades, use plastic scraper to remove built up layer of thatch, check belts, spray a spray can lubricant onto the underside to both prevent rusting and to prevent grass buildup, grease zerks, reattach blades, flip upright. Some spray can type things could be WD-40, Pam, etc. You could also wipe on a low viscosity oil: a vegetable type cooking oil, machine oil, etc. This would prevent Oxygen from getting to the iron and keep clippings for sticking. He recommended once a year, but I would think it wouldn't stay that long. I'd also have concerns about getting it on belts for those decks that have them.
   / Rustproofing mower decks #5
I use old crankcase oil.
After about two mowing sessions (about 8 hours of steady mowing) I remove the mowing deck, take off the blades for sharpening, scrape off the built up grass clippings from the bottom of the deck, and paint on a layer of used crackcase oil, and grease the zert fittings.
I probably should scrape off the grass clipping build up after every every mowing session.
I do this same procedure at the end of mowing season.
Come spring there is still a layer of used crankcase oil on the mower deck.
   / Rustproofing mower decks #6
All the lubricants I mentioned are biologically safe. Crankcase oil comes off with the clippings and gets into the soil. This is very toxic to the environment.
   / Rustproofing mower decks #7
Excellent idea !!!! Another good use for crankcase oil.
   / Rustproofing mower decks #8
If you let the authorities catch you getting oil in Squaw Creek and the Truckee River, you may not think the idea was so excellent.
UNUSED FUTURE RC CEMENT TRUCK TOY (A51243)
UNUSED FUTURE RC...
2018 CAT 320GC Excavator (A47384)
2018 CAT 320GC...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
John Deere 6175M (A50120)
John Deere 6175M...
2016 TRAIL-EZE TE80HT 102" X 48' STEP DECK TRAILER (A51243)
2016 TRAIL-EZE...
