Rust in large gas storage tank
   / Rust in large gas storage tank #1
wjoerob
Franklin IN
Kubota 6100
What's the best way to get rust out of a large (300 gal.) gasoline storage tank? I've seen some discussion on here about smaller tanks. Bought this with a stand about 2 yrs. ago, discovered it has some rust, but no obvious holes. It does have a place for a paper filter above the hose and nozzle. Someone mentioned Evapo-Rust, does that work for larger use? I'd like to store gasoline when the prices are low -- wish I'd done it 4-5 yrs. ago...
   / Rust in large gas storage tank #2
You could build some kind of rotating frame to put it in and put some gravel inside. Spin it around for a couple days. Make sure to call Guiness 1st though, it might be the worlds largest rock tumbler.
   / Rust in large gas storage tank #3
Wonder if your bulk fuel supplier would have any ideas. Surely they run into this from time to time.
MarkV
   / Rust in large gas storage tank #4
What ya gonna do with it after you clean it out ?
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
PALLET OF NYLON SLINGS, METAL TOOLBOX W/ CHAINS (A54757)
PALLET OF NYLON...
Year: 2009 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 Door C... (A55788)
Year: 2009 Make...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A55851)
2016 Godwin CD150M...
2005 Sterling Acterra Tender Truck (A55301)
2005 Sterling...
