Rust around fuel tank neck
   / Rust around fuel tank neck #1
1Lawman
Joaquin, TX
2012 John Deere 5093E
I have a 2012 model John Deere 5093E. There is significant light rust around the filler neck, chain that attaches to the screw on fuel cap and a small spring in the cap..Any idea what could account for this?
   / Rust around fuel tank neck #2
I would assume it has a plastic tank. It is common to get rust around the filler neck on older metal tanks from water in fuel and just plain ole humidity . If it is plastic I would say it algae that's accumulating
Yes the tank is plastic..The rust is already somewhat pitted and the tractor is only a 2012 model..Is there any way to keep it from getting worse?
   / Rust around fuel tank neck #4
plastic does not rust , It has to be something else
The tank is plastic. The filler neck, chain and spring are metal
thnks
   / Rust around fuel tank neck #9
I concur, it's condensation from a partially full fuel tank, it happens a lot on older tractors, I pulled a fuel tank off my dad's 1950 Case SC that sat for 20 or so years, the top of the metal tank had 4-5 holes in it big enough that I could stick my finger in.
Only way to stop or slow it down is keep the tank full all the time but the neck would be more tricky.
Tractor Pallet Fork Frame (A51573)
Tractor Pallet...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
