Rural King Service
   / Rural King Service #1
RickDpwv
Princeton, WV
Rural King RK24H
In the past week I have had, what I consider, a big problem with my RK24 H tractor, It was actually dangerous to operate. Pressing the brake, or turning the front wheel sharply to the left or right would make the tractor go forward.I was sure it was a problem with the hydraulic transmission... . Turned out to be a problem with missing/loose frame bolts from the frame to the transmission on the right rear of the tractor. Apparently my tractor, after running about 10 hours with a 4' foot King Kutter Brush Hog ( I have a total of 24 hours on the tractor) created enough vibration to loosen 3 frame bolts and loose 2 more frame bolts on the right rear side of my tractor. I do not attribute this problem to King Kutter; but to the tractor. I felt no vibration during operation of the tractor. I would like to offer this public service announcement to other Rk24 owners;Please check every bolt on your tractor!!!. In addition to the missing and loose frame bolts on the right side of the transmission I have found loose bolts on the left rear of the transmission and in the left front axle. In both cases I have fluid leaks. My local Rural King has taken care of all issue except for the front left axle leak. I am expecting it to be resolved at the 50 hour service interval.
   / Rural King Service #2
Thanks, will be checking mine today.
   / Rural King Service #3
Thanks for the heads up. I'll be doing my 50hr maintenance this week so I'll take a look at the bolts while I'm under there.
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
2022 LOAD TRAIL GOOSENECK TRAILER (A52472)
2022 LOAD TRAIL...
2000 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
2000 HEIL TRAILER...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A52748)
UNVERFERTH 330 8...
Miller Wildcat 350-D Welder (A51691)
Miller Wildcat...
