running problem
   / running problem #1
st stepen , sc
allis - chalmers 180 diesel
Have an Allis - Chalmers 180 ( diesel ) , starts right up & will only run @ an idle for a min or two then stalls . Can start & rev up but it will idle down & stall . It has new clean fuel . fuel filter & Injectors have been bled . Have put a new plunger in the Hand Primer Pump .
   / running problem #2
Welcome to TBN - I had nearly identical symptoms on my AC 160 a couple weeks ago - on mine, there's a second sediment bowl just ahead of the fuel pump - on closer look, I found a greenish disk hiding up inside the housing where the clear bowl mounts. Turned out that greenish stuff was algae - the disk itself is kind of a "micro-fiber", and was about 98% plugged solid with algae. Used almost a full can of carb cleaner from both sides before that disk looked right; put everything back together, bled it and away we go...
Dunno if that's the filter you referred to, but if not you may wanna check it out on yours... Steve
   / running problem
Thank you !
Mine has only a spin on canister fuel filter between the tank and the Injector pump ....
   / running problem #4
G'day Mate and welcome to TBN from Downunder.
BukitCase has the right of it and I had a similar symptom case just a couple of months ago. Biological growth in the fuel tank which progressed through the fuel system. There are many fuel additives containing 'biocide'.
If you can get your hands on an 'inspection camera' (borrow or purchase), have a look inside your tank to confirm before you start firing the parts cannon at the problem. If you've got a growth in the bottom of your tank, it'll look like cotton-candy mixed with phlegm.
   / running problem
G'day , I will look into that .
Thank you
   / running problem #7
If you narrow it down to the injection pump, flex ring.. I can take care of that for ya..
Loosen the side cover & let some fuel run while the engine is running, before it shuts off..
IF it stays running, your return line is clogged.. either from garbage in the system or a broken flex ring inside the pump..
You can remove the fitting on top of the pump also and just let the fuel run.. and start it.. it'll tell you the same thing..
BTW> I'm on the upper lake, right on your back door.
100 GAL FUEL TANK W/PUMP (A52472)
100 GAL FUEL TANK...
2017 JOHN DEERE 8270R LOT NUMBER 189 (A53084)
2017 JOHN DEERE...
2019 Ford F-550 Service Truck, VIN # 1FDUF5HY1KEF71327 (A51572)
2019 Ford F-550...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
