HomesteadOC
Ive got a new to me kubota b7100hst-d serial number shows 90-91 but the seller says it was a 95 model year. Anyway Im pretty sure the hydraulic pump is 1700psi at 3gpm. I really want to run a hydraulic chainsaw and/or pole saw off of the 3ph aux port under my seat. Most newer saws are switchable from OC to CC, but Im not sure what that aux valve is on the tractor. Also most used saws Ive found meet the pressure requirement of my tractor but not the flow. Theyre usually in the 4+gpm range, is 3gpm going to barely work ok? If not, the other option is to add a PTO hydraulic pump that matches perfectly. Id prefer to run that off of my mid PTO where a deck finish mower would take power from. Ive looked around for these, but havent had much luck, does anyone have a source for a 2500rpm pump like this?
Thanks for all the help!
