running gear/hay wagon bearing-seal info
   / running gear/hay wagon bearing-seal info #1
george88
Howdy,
I purchased a wreck of an old running gear for $50 and am getting a great basic lesson. I believe it is an old electric.
I pulled one wheel off and removed the bearings. The bearings are both Timkens and the inside is a 14136A. None of the wheels have any grease seals. Does anyone know if they came with grease seals (I assume they would). How do I determine which grease seals to replace without a number.
Also the wheels are five hole 15". Any good place to find these, since they are fairly rusted out?
This is kinda fun for a non-mechanic.
george
Kansas
UNUSED 30PCS Brown Metal Roof Panels (A53117)
UNUSED 30PCS Brown...
2015 Toyota Prius (A53424)
2015 Toyota Prius...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
Harrell 3605 (A50123)
UNUSED Jack Lift 5/10 Ton (A53117)
UNUSED Jack Lift...
