Running fel from b/h pto pump
   / Running fel from b/h pto pump #1
Timothy
I have been having problems with Jinma 354 ZL 30 fel , blown tractor hydraulic pump , I have always had concerns as oil gets hot . My solution is to use LiTW bachhoe pump to power both backhoe and fel , the backhoe oiltank is 22 litres as apposed to the tractor's 8.8 lts. so oilshould stay cooler . Have ordered after market loader valve from Ranchhand , this valve has power beyond so I propose to plumb pto pump to the fel valve , power beyond to backhoe (7600)and t return for fel to backhoe return just before the filter that goes to tank . Am I correct in my plumbing ? This set up would allow me to use the tractor hydraulic pump as bach up in case of problems . Timothy
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A53472)
2023 New Holland...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
