fourwheelinj1
- Joined
- Oct 23, 2015
- Messages
- 13
- Location
- Raleigh, NC
- Tractor
- International Super A, 444,Super M, 656
Let me start off by saying that my knowledge of hydraulics is very limited. I have a bobcat 442 excavator that is plumbed with auxiliary hydraulics. I currently have a hydraulic thumb and have an additional set of remotes along with what i am pretty sure is a large case drain line. I would love to have a commercially made mulcher or brush hog specially made for excavators but the budget isn't there for that. I do however have a couple of old tractor 540 pto bush hogs I would like to convert to run off the excavator so we can mow pond banks and other hard to reach areas. I would like to add a hydraulic motor to the existing bush hog to turn the factory pto gearbox. My specs on my machine say the auxiliary system has a max working pressure of 4,060 psi and a flow (adjustable) maximum 26.4 gpm. Can someone help me figure out what I would need in the way of a pump and cushion valving to make a working system that won't harm my machine? I am really just looking for a little education so I can get this designed. I am not expecting the performance of a commercially available unit but I would like it to be able to knock down thick brush. I have found a few motors that might work but the psi ratings are usually only 2500-3500. Can I lower my psi on my auxiliary to be able to use a lower psi motor?
