Run Away Diesel
   / Run Away Diesel #2
I don't know how to react to a locomotive, except run!
As far as personal equipment, your options for saving the engine are cutting off the air coming into the engine or discharging a C02 extinguisher in the intake.
Diesels can "run away" for several reasons, most commonly because of bad injection pumps or getting the engine in such a position that it burns its own oil (like flipping the machine on its side).
   / Run Away Diesel #3
I have heard but never seen the deck engine on a drilling rig try and run away. This can be caused by a fuel source in the air getting into the motor. There is also the possibility of the motor stalling out and running in reverse if something connected to the motor is able to bump it over backwards. Again this is from the drilling industry. I have a feeling that a electric diesel is not as susceptible to this as a mechanical engine would be!
   / Run Away Diesel #4
Any source of fuel into the air intake will power the engine. A leaking turbo seal, spilled fuel, fuel injector not cutting off, and of course a injector pump failure.
As a teen ager I was cleaning the air filter on my dads 2020 John Deere. It was a oil bath wire mesh type and I cleaned the mesh with gasoline, and put it back together and started the engine which then instantly reved for a few seconds way higher than normal engine speed, it was screaming, like all **** breaking loose kind of thing. Only reason it did not destruct is that the supply of wet gas was limited to what ever did not drip out when I reinstalled it. At the time I barely understood what had happened but to this day I wonder why it did not swallow a valve or something. That thing was screaming.
   / Run Away Diesel #5
When I was in the Army I saw several engines after they had run away and it wasn't nnice. I personally saw 2 different engines runaway and both were Detroit diesels. One I was in a truck mounted crane working and the engine took off not a lot of room to move around in there. We always let the cp on the air cleaners loose so it could be removed and flipped over. If standing beside one while running away don't get you heart rate you must be dead
   / Run Away Diesel #6
Happened to my Kioti DK 45, twice. Was a frightening experience. I was sure the engine was going to blow, had lots of room to maneuver through the fields until I got it stopped by stalling it. Turned out the injector pumps were bad.
   / Run Away Diesel #7
One of these or just a simple clip gate valve.[video]http://www.amot.com/products/air-intake-shutoff-valves[/video]
There are areas where Disel Engines are not allowed if they do not have positive air shutoff.
   / Run Away Diesel #8
I got elected to shut off a friend's Mercedes one evening. Wouldn't shut down when he turned of the key, and he's mechanically hopeless. We drove it to the dealer and parked it by the service bays, and I stuffed my Levi jacket into the intake. At least it was just idling.
   / Run Away Diesel #9
If you can stall it or at least bog it down until it runs out of whatever is causing the runaway, chances are you can save the engine. Years ago I was was discing a field while a friend was plowing the next field over with our farm's open station JD 4320 and, if I remember right, a six bottom plow. After a while I noticed his tractor was really moving across the field, blowing black smoke, soil flying behind the plow, and with him standing up. I thought to myself that fool was really working the tractor too hard but, little did I know at the time, the tractor's engine was running away. It was running on its own motor oil because of a blown turbo oil seal and he was doing his best to get it stopped. My quick thinking friend had put the plow all the way in the ground and was standing on the brakes with all his might trying to stall the tractor when he couldn't get it shut down normally. It finally stopped when it ran out of motor oil. Because the RPM's had stayed down during the runaway, we ended up just rebuilding the turbo because there seemed to be no other damage. We continued to use the tractor for another 5 years until we replaced it with a newer tractor.
   / Run Away Diesel #10
that's still a scary ride! at what point would one admit he couldn't slow it down and have to jump????
yikes
2013 FREIGHTLINER CASCADIA(INOPERABLE) (A45046)
2013 FREIGHTLINER...
2015 Ford F-150 Ext. Cab Pickup Truck (A44572)
2015 Ford F-150...
2020 BOBCAT S595 (A45046)
2020 BOBCAT S595...
2014 FREIGHTLINER M2 TANDEM AXLE FLATBED WITH MOFFETT HOOK UP (A43004)
2014 FREIGHTLINER...
2018 GENIE GS3246 (A45046)
2018 GENIE GS3246...
OKC-NICHOLS HILLS PROPERTY (A45333)
OKC-NICHOLS HILLS...
