Rubber rollers vs flails
   / Rubber rollers vs flails #1
Jd6403
Lincoln, Texas
John Deere 6403
What's the difference? Which one is better for coastal?
   / Rubber rollers vs flails #2
What is this about? :confused3:
   / Rubber rollers vs flails #3
I'm assuming mower conditioner's. Flails will be harsher & beat the grass more than rubber.
I've never cut Coastal before, so I guess I really cant help there.
   / Rubber rollers vs flails #5
i think the rollers are better on crops that have leaves on them. my disc mower has flails, and is very good on grass hay.
   / Rubber rollers vs flails #6
Ah, so you have a twin 4 blade disc mower;
You could call it a horizontal flail, knife but its a single edge mower blade which is used with the other 7 on the twin disc's to cut, carry, and lift the hay up and over the twin discs and let it set down again
The rubber paddle flails are used to top sugar beets a few minutes before
harvesting them.
   / Rubber rollers vs flails #7
If you are baling coastal bermuda the disc mower would be better to reduce leaf shatter than a swather with rubber krimper rolls.
   / Rubber rollers vs flails #8
harvesting them.
i have a 9'2" disc mower with flail conditioners.
EZGO (A50324)
EZGO (A50324)
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
2013 Caterpillar 950K Articulated Wheel Loader (A51691)
2013 Caterpillar...
2011 FORD F-450 (A52472)
2011 FORD F-450...
