rubber rake teeth vs steel
   / rubber rake teeth vs steel #1
ejm15
pickton tx
kubota mx 5100
Hey guys, so I have 2 side delivery hay rakes, a NH 256 and a NH 56. The 256 has rubber teeth and the 56 has the steel kind. I just bought the 56 and have no experience w/ the metal tines and I only need one rake so I would prefer to keep the one with the good/better teeth? :confused3:
Your :2cents: is appreciated
Thanks for the input. :thumbsup:
   / rubber rake teeth vs steel #2
Rubber teeth were considered an upgrade on NH rakes. They broke off less so less "iron" left in the field. That said if your raking needs are modest, I would keep the teeth in better shape. I would also keep the 256 rake as it is newer. The teeth are interchangeable between rakes. The steel teeth are cheaper to replace.
   / rubber rake teeth vs steel #3
Keep the 256 its a newer rake. True, the steel rake teeth are cheaper to replace but . . . .When they break off, and they will, in my past experiences they always pick up in a tire of a truck, tractor, baler or loaded wagon of hay headed to the barn to beat an incoming rain storm. Its up to you, our rake had rubber teeth . . . .John
Alright guys, thanks for the replies.
   / rubber rake teeth vs steel #5
Back in the old days when they came out with rubber we switched all of ours over. Well worth doing it before season rather than replace as fail.
2025 Swict 60in Bucket Skid Steer Attachment (A55787)
2025 Swict 60in...
2015 Ford Taurus SE Sedan (A54815)
2015 Ford Taurus...
2016 Ford E-450 LP Handicapped Bus (A53422)
2016 Ford E-450 LP...
2013 Ford F150 4X4 Pickup Truck (A53422)
2013 Ford F150 4X4...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
