Rake Rubber hay rake teeth
   / Rubber hay rake teeth #1
DirtyDusty
North Louisiana
New Holland TN75
I have a ford hay rake that has rubber mounted teeth on it. They are breaking off and the only replacements I can find are from the New Holland dealer at $12 each. TSC has after market teeth for less than 2 bucks, but none fit the ford. Does anyone know of a source for aftermarket teeth? is there another type of tooth that will fit the rake?
   / Rubber hay rake teeth #2
Can you use the spring teeth from New Holland? I am changing all my rubber mounts to springs as they break. the TSC teeth are junk and do not hold up anywhere near as long as the NH teeth. I tried them once, ended up having to replace the same teeth by the end of the year as they all broke off:(
The spring teeth when I last bought them were actually cheaper then the rubber mounted teeth. that was including the clamp and bolt for the spring teeth. I haven't broke any of the spring teeth yet in the two years I have been using them.
KUBOTA ZG327 ZERO TURN LAWNMOWER (A51243)
KUBOTA ZG327 ZERO...
2016 GEHL RS5-19 TELESCOPIC FORKLIFT (A51242)
2016 GEHL RS5-19...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2019 CATERPILLAR D6N LGP HI TRACK CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2014 UTILITY 53X102 DRY VAN TRAILER (A52141)
2014 UTILITY...
