RTV900 Plow Electric Lift Linear Actuator
   / RTV900 Plow Electric Lift Linear Actuator #1
lloyd123
Taxachusetts
RTV-X1100C
I've seen the lift motor for the RTV900 (Curtis) plow listed as "electric over hydraulic" in several posts but when I did some searching on this it turns out that it isn't. It's actually a electric/mechanical set up with a acme screw doing the lifting. There's a stainless steel tube covering the screw that makes it look like a hydraulic piston.
Here's the manufacturer's web site:
http://www.thomsonindustries.com/Sections/Products/Products_main.asp?PC=8900105&L=True&IT=Descrip&GI=1
I found another site that sells the unit for $250:
http://www.powerdrives.com/electrak/D12-10A5-04D.htm
I sent an e-mail to the company to see if they had repair kits. They wrote back that the only replacement part they sell is the motor for $125. I think it will be the clutch that wears out first. According to a chart the clutch should be good for about 10,000 cycles before it fails. If you don't run the motor until the clutch starts to ratchet then it should be good for about 50,000 cycles.
I don't know what Kubota or Curtis charges for a replacement but I bet it's more than $250.
   / RTV900 Plow Electric Lift Linear Actuator #2
Hey George,
Hate to say it but I think you and Frank (flyingn) are the only 2 that can actually say the subject line of this thread "3 times fast". /forums/images/graemlins/shocked.gif
Kidding aside, I just saw a plow related item that I'm not sure you could use. Check out e-bay Item number: 4520743402
Not sure if it would/could work for you but just wanted to pass on what I saw. /forums/images/graemlins/wink.gif
Brian
Brian,
It was either "RTV900 Plow Electric Lift Linear Actuator" or "Plow Thingy". They don't charge by the letter so I went with the first.
Thanks for the link - I already installed the Kubota angle kit but it looks like someone with some mechanical skills could get this to work on the RTV - BTW, that wouldn't be me.
I see that ebay seller with the hydraulic unit also has another interesting item - a "mother-in-law" buggy for a ATV/UTV:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&tc=photo&item=4530800277&category=43971
   / RTV900 Plow Electric Lift Linear Actuator #4
wow,, its NOT hydraulic?? Interesting.... I have to be careful of the ratcheting when I raise it too.
Frank
   / RTV900 Plow Electric Lift Linear Actuator #5
Thats great info. I get lazy and I dont watch the plow I have been just waiting to hear the noise and then I let go of the button. I guess I wont be doing that anymore. Thanks again for the info.
This is kind of a follow up to my original post - I checked with the Curtis Company in Worcester, MA - only about a 15 min ride for me to their factory - and was given the following prices for the 72" Plow replacement parts:
Cutting edge - $60
Lift actuator - $310 - No repair parts available
Skid shoe - $9.50. This price seems low to me. Maybe it's because it's just one shoe. I've seen other prices on the internet for the 72" Kawasaki Plow (same as the Kubota - made by Curtis) for almost $50. That may include two shoes, the adjustment washers and the cotter pins. I also may have misunderstood the salesman. Dozernut offered me his bifocals the other day because I misread one of his post. Do you have a hearing aid I can borrow as well? /forums/images/graemlins/smile.gif
   / RTV900 Plow Electric Lift Linear Actuator #7
Loyd
Don't get impatient, I am slowly going deaf too /forums/images/graemlins/shocked.gif! I do have a Hunters Ear I could loan you, but would need it back before hunting season /forums/images/graemlins/grin.gif!
Please don't take my very dry sense of humor too seriously, it was all in jest!
Dozernut,
I don't take anything too seroiusly - just ask my wife. I can appreciate a dry sense of humor as well - no problem. I beleive we have a lot in commom - empty nesters - bifocals (verilux) and a RTV with a plow.
BTW, I can remember some photos you posted last year and I recall that you have a gravel driveway(?). Have you noticed much wear on your blade/shoes?
   / RTV900 Plow Electric Lift Linear Actuator #9
First snow that I bladed, I lost both skid shoes. I eventually found them when the snow melted. I didn't bother to put them back on, one the shaft is bent, and I am in the process of building a heavier set that will not come off unless I want them off. I think some vines (Honey Suckle) reached out and "grabbed" the rings on the pins and vibration made the pins drop out. I have a little wear on the cutting edge but it is not too significant. I will probably have to replace the cutting edge in 2-3 years. Other than that I am satisfied with the blade/RTV performance.
2013 Chevrolet Caprice Sedan (A42744)
2013 Chevrolet...
2023 Kubota KX033-4 Mini Excavator  Only 98 Hours (A44789)
2023 Kubota...
Case IH 5866 (A44501)
2014 Ford Explorer AWD SUV (A42744)
2014 Ford Explorer...
2007 Thomas School Bus  Freightliner Chassis, MBE-900 Diesel (Non-Running) (A44789)
2007 Thomas School...
2012 TURNKEY INDUSTRIES DATA VAN TRAILER (A45333)
2012 TURNKEY...
