rtv900 ball joint
   / rtv900 ball joint #1
Nwood
checked over the rtv and one of the lower ball joints was loose.
the ball joint is ok but its like the nut was not ever tightened properly before it was pinned. figured no problem i'll tighten that up. But the nut and threaded part both spin together and i cant see a way to tighten or remove the nut.
any ideas?
Dean
   / rtv900 ball joint #2
impact gun won't work?
   / rtv900 ball joint #3
Most Ball joints have a tapered shaft. The best way to tighten the securing nut is to 'load' the ball joint. This can be accomplished in 2 ways, place a floor jack under the ball joint and jack up the RTV. This 'loads' the ball joint shaft into the lower arm ( coil spring / strut applies downward pressure). The 2nd way is use a large pair of channel lock / water pump pliers and basically do the same, one jaw on the bottom of the ball joint and the other on the lower arm. To ease the installation of the securing nut, ensure the ball joint stem threads are clean and undamaged. Once you obtain enough preload on the shaft, you can secure the nut to proper torque.
   / rtv900 ball joint
thanks, the ball is loaded with its normal weight, i can jack it to apply more pressure. got a little rust going on the threads, hope it comes loose or tightens for me. spinny spinny is no good.
D
2012 Peterbilt 382 T/A Day Cab Truck Tractor (A50323)
2012 Peterbilt 382...
2005 Mercedes-Benz C-Class Sedan (A50324)
2005 Mercedes-Benz...
1997 International F-4900 T/A Dump Truck (A50323)
1997 International...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
2010 Honda CR-V Multipurpose Vehicle (A51694)
2010 Honda CR-V...
Year: 2013 Make: Kia Model: Soul Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 144,857 Plate: (A51694)
Year: 2013 Make...
