s219
Super Member
- Joined
- Dec 7, 2011
- Messages
- 8,548
- Location
- Virginia USA
- Tractor
- Kubota L3200, Deere X380, Kubota RTV-X
So I did the 50-hour service on my RTV yesterday, which included changing the two hydraulic filters on the back. The smaller HST filter came off easily and I barely lost any fluid replacing it. The larger suction filter was stuck on beyond belief, and I had to drive a screwdriver through it, multiple times, to get it off. Could barely get one full turn out of it after stabbing and rotating little by little, three times, and the rubber gasket made an awful squeak noise until it broke free -- seems like they must have put it on originally with no lube on the gasket.
Anyhow, in the process of murdering that big filter, I lost a fair amount of fluid. Per the manual, after replacing those filters, the fluid level in the transmission case should be checked and fluid topped off as needed. Well, that particular dipstick (yellow plastic, on the top center of the transmission, under the dump bed) read full and kept reading full even after running the engine. I checked the hydraulic tank dipstick, which is under the passenger seat, and it read very low and took about 2.5 quarts of UDT-2 to come back to full.
I spent some time studying the hydraulic plumbing, and it seems to me that the reservoir is connected to the transmission -- the same line that feeds from the reservoir through the oil cooler loops back to the transmission, plus the control valve lines for the dump bed cylinder come out of the transmission. Seems like it's one big common system, but with multiple dipsticks and a couple of reservoir points.
I guess I am at a loss why the owner's manual says to check the transmission fluid level after the filter changes, but mentions nothing about the tank under the seat. It's as if they are separate systems. I would think someone could get in big trouble if they did what I did, but only checked the transmission dipstick and didn't question things, or know to check that other (more hidden and not obvious at all) reservoir/dipstick under the seat.
Maybe one has to drain or lose much more fluid through the transmission case itself before that runs low and can't siphon off the tank? Any other thoughts or insight? As it is now, I know I lost about 1/2 gallon of fluid based on what collected in the kitty litter box I used to catch drips, and I know I added back about 2.5 quarts, so if I step back and look at it in an overall sense, I should be more or less back to normal.
