RTV Steering Problem
   / RTV Steering Problem #1
Will_C
Veteran Member
Upstate N.Y.
Kubota L3560, Toro 52" and 60" ZTRs, Kubota RTV 900
I need some advice for a friend. Started his RTV 900 yesterday, no steering-turn the wheel and nothing happens,it just spins. He has a fairly low hour machine, other hydraulics (dump bed) work, and the machines drives. He lives 20 miles away, so I have not looked at the machine myself-he did say he checked the fluid and it is full.
Any ideas?
Thanks,
Will
Sent from my iPhone using TractorByNet
   / RTV Steering Problem #2
The dump bed and power steering work off of different hydraulic tanks. The power steering tank is uner the seat nect to the antifreeze overflow tank. He may have water in the system and it wasn't a problem untill the cold set in and could be frozen. Look into the power steering tank under the seat and if the fuild is cloudy that could be the issue.
   / RTV Steering Problem #3
I need some advice ......, no steering-turn the wheel and nothing happens,it just spins.
Mikesee is correct about the 2 different hydro systems...........Actually if you count the power steering, it would be 3........but..........to me something else is going on as even with NO power steering the machine will still turn the wheels while rotating the steering wheel. It would seem that something is totally broken, like the steering wheel itself or tie rods...........God bless..........Dennis
I'll see him at work tomorrow and pass on your thoughts.
Thanks,
Will
2014 Dynapac CC4200 (A51039)
2014 Dynapac...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2013 John Deere 4730 Self-Propelled Sprayer (A51039)
2013 John Deere...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2017 FREIGHTLINER M2 BOX TRUCK (A51222)
2017 FREIGHTLINER...
